can anyone please explain how you execute skinmaker.exe?
the help file says "To compile skin you should type:
SkinMaker.exe file_name".... type where??
executing skinmaker exe, trkr3
It's probably a lot better to use the batch file "build". The skinmaker.exe should be ran from the command prompt but it does the same thing as "build" does.
