I know that this is possible on other phones that use SIM cards but is there any way to set my 3650 to save my contacts on the SIM instead of system memory?
Thanks in advance
Kevin
Thanks in advance
Kevin
You can save them one by one,not all at once.And you can't have multiple number entries under one contact.
I was afraid that that was going to be the answer. Thanks!
I believe that might be incorrect.
It is possible to backup all contacts onto SIM, (I think).
If your phone does not allow it, perhaps it varies by regional provider.
My phone is not here so I cannot check this.
Its possible with other phone,IE:t68i but not with a 3650.
