Trouble setting up BT
1 replies · 1,330 views · Started 19 October 2003
HELP!!!!
i'm been trying like mad to connect my 3650 to my BT adapter and i'm not sure what i'm doing wrong.
i have an ambicom bt adapter and i installed the bt neighbor software that came with the adapter. after installing pc suite i tried to connect to the port designated for the serial port which was COM 3 in the mrouter, but it doesnt work.
i try pairing my phone with the router but no luck ... wen i pair the phone with the given bt neighborhood software it works..... i try to open the pc suite but it tells me to connect my phone.....arrrgghhh!!!
can somebody help me and let me kno what exactly i need to do or what i'm doing wrong. thanks in advance!
Do search, you'll find loads of info.
Try these.
Open Mrouter and check ALL the BT COM ports and see which one works for you - normally you need 2 com ports checke not jus one.
Also try right clicking the BT icon on you sys tray and select 'services' then 'serial port' then select your phone from the chooser.
Best
Will
