That BT Car from SE, where some of you guys were so enthusiastiac about (including me) has been reviewed by Mobile-Review
http://www.mobile-review.com/review/sonyericcson-btcar.shtml
Although the article is only in Russian at the moment, you can see some nice pics. The English translation of a review usually follows a few days later, so I guess we'll need to have a bit more patience for that
Tried babel fish on it, you can get the jist of it...
Babel Fish Translation
In English:
Company the sones Of erichsson began to produce automobiles, yes not usual, but racing bolides.Here their only sizes/dimensions only is more than match box, can easily be hidden this machine in the pocket.Uncommon accessory was called name bluyetootyu of cups/sorcery, as it follows from the name, typewriter/machine is governed/controlled with the aid of to bluyetootyu from the mobile telephone.Compatability is supported only with the telephones the sones Of erichsson by those equipped with this function.Typewriter/machine is recharged from the telephone itself, it has the appropriate joint for the connection to it.Construction/design looks uncommonly, the indicator of red color burns with the charging under the frontal glass.To charge the typewriter/machine is possible both of the minutes 15 and to the hour, no longer it costs, since the capacities/capacitances of the built-in storage battery/accumulator will not be sufficient.The presence of this joint for the charging is caused first of all by the unwillingness of company so that this accessory would be used with the apparatuses of other producers.One charging is sufficient to the pair of the hours of use, you can drive in the calm manner of urban teapot, so attempt to imagine yourselves by Schumacher, it suffices to only change the speed of machine.In all it is accessible two speeds for the typewriter/machine.Complete administration is accomplished from the telephone, dzhoystik or navigation key immediately transfer your commands, and typewriter/machine already follows im. during the half-hour it is possible to be adapted to control and to begin to master the routes/courses, which here are built from improvised materials, books, rules, other domestic objects/subjects.Even you realize through the pair of hours, that they did not note, as they would fly, although nothing special like and they made.This toy is ideal for the children, they cannot be detached away from it.But adult, as it is long ago known, these are the same children, but with the more expensive toys.Typewriter/machine from the sones Of erichsson falls under exactly in this discharge/digit, its cost/value is order 100 dollars, and it is let out by small parties/batches for thousands of pieces, so that to find typewriter/machine in any of the stores is cannot. For the sake of fairness it is worthwhile to note that in the children's stores it is possible to purchase the radio-controlled models of machines, they cost from 20 to 50 dollars, but have somewhat larger sizes/dimensions.Typewriter/machine from the sones Of erichsson is interesting by design and precisely fact that it is governed/controlled from the telephone.this of its kind fashionable accessory for those, who attained in the life of the specific position and it can allow itself this whim.In Russia the typewriters/machines are thus far noted were not, the first copies will here appear only during January of 2004 years. I want to note in the time of usage of a typewriter/machine in Moscow that it caused genuine interest among all, in some ofisakh generally they ceased to work and pickers were arranged.In the incomplete three days your obedient servant was introduced because of the typewriter/machine to the mass of new people, usually this for me succeeds only in 1.5-2 months, even then with the very active intercourse.
Thanks for that! But I'm still happy they will go and translate it themselves😉
Yeah, they should make a better job of it! Some of it did read a bit odd! 😃
Well, the translation is completed by Mobile-Review (it's not the best translation possible, but better as that gibberish from Babbelfish😉 😃 )
http://www.mobile-review.com/review/sonyericcson-btcar-en.shtml
