How do I use one of my Mp3s as a ringtone./??? I can't find the option anywhere...
any ideas>?
any ideas>?
just put them mp3 files on your Ngage memory card via Nokia Audio program (USB Cable)...
then go to profiles, choose personalize and pick your MP3 file, which should show up in there =)
Greetz, Andy
What folder can I copy them to using fexplorer on the ngages built in memory so they show up in the ringtones area still>?
You can put them anywhere on the memory card or device memory. The phone will automatically find them. If yuor still having trouble with it make sure your mp3's aren't corrupted in any way.
SAbz
To be used as ringtones, the files need to be in c:\Nokia\Sounds or e:\Nokia\Sounds (the built-in ringtones are in z:\Nokia\Sounds). Polyphonic sound files in .\Digital under these directories.
They say you can't use mp3 ringtones on the QD , m but you could with the old N-Gage
AndyLuft wrote:just put them mp3 files on your Ngage memory card via Nokia Audio program (USB Cable)...then go to profiles, choose personalize and pick your MP3 file, which should show up in there =)
Greetz, Andy
I can put mp3 and choose it in the general profile for example but i can't set MP3 file as a ringtone for a group.i just see .mids and .amr any idea ?
qd got no build in mp3 player so cannot use mp3 as ringtone
seacher wrote:qd got no build in mp3 player so cannot use mp3 as ringtone
rootytooty wrote:By downloading MP3 player software does it make the QD able to do MP3s???
Thanks,
Bobbyr
