I am trying to install the skinmaker ? how ???? doe we have to install it form the zip file.
the exe file and the dll file, i have truyed it but does not do anything when i double click on the skinmaker.exe file (to install)
greg😕
greg😕
You'll have to modify the other files using notepad.
page1, page2, the bitmaps and all only then can you run the skinmaker file using the batch program.
You'll get a ktz file to send to your phone via BT or infra.
Then from Tracker: import.
Bascially, you need some basic programming skill for it. By looking at the sample code given from symbianware.com's example, it's rather easy to do your own skin, but need a real patience...
i too have problems with setups 😞
i get these things
but all i get is error message...
not digitally assigned
