So what would your 3 top changes or additions would you like to see for the 9210.
Mine
1. USB Connection.
2. Touch Screen.
3. More memory.
Mine
1. USB Connection.
2. Touch Screen.
3. More memory.
[quote]
Mine
1. USB Connection.
2. Touch Screen.
3. More memory.
4. Support GPRS and Bluetooth.
5. Stereophonic Audio.
I dont have a 9210 so this is more from observations and what I feel is missing from the device.
1. More memory (internal shoud be more like 16MB) - MMC Card is fine but a 32MB wouldn't hurt.
2. USB Connection together with improved connectivity software. I like to have an option for viewing the Calendar / Contacts / E-mails in a basic set of apps rather like the Palm Desktop. This is OK at the moment I guess if you Sync with Outlook.
3. GRPS / Bluetooth - main reason they aren't there is because they not fully developeed I guess. - maybe in the 9210g?
4. Anything to make it smaller providing screen does not get smaller.
5. Bigger buttons on the phone side - why waster all that surface area?
1. USB connectivity, hence PC/9210 drivers
2. More...more..device memory
3. TRI-BAND CAPABILITY
4. PC-simulator reading MMC (aka palm)
Hi There,
My (extended) top three would have to be
1. More memory
2. USB Connectivity
3. Touch Screen
4. Stereo Audio
5. Vibrating alert
6. GPRS/Bluetooth
PointyThing
...GPRS would be the best add-on.
a functional connectivity to palm handhelds (not only contacts) would also be nice.
I just want that somebody makes universal remote control programm to my 9210. It's all i need cos i'm not a palm owner.
I guess you all know this but if you format device memory and install "all_nokia_9210_data.sis" with pc suite, it ask where you want to install... I have installed all softwares to MMC and there is lot of memory free in device + if you have more than 16mb mmc (32 is good, i have 64mb) , then you have lot of memory free at mmc also.
See ya
Top3 for me are as follows
Improve Connectivity - USB, better PC Suite supporting File Sync and Note Sync.
More internal Memory
Bluetooth/GPRS
I would actually rather not have a touch screen. Having used one on PPCs over the last couple of years, I quite like the Nokia interface. It is more prone to problems of bad applications design, but where the applications are written well, it is just as good for most things (IMHO).
Zuber
1) I would like to have both a CompactFlash type II slot and a MultiMediaCard Slot.
2) More system memory.
3) Stereo headphone jack.
I would like
1. More ROM
2. Bigger capacity MMC's
3. USB port compatibility
4. External keyboard USB slot
5. Bluetooth
Very interesting everyone. I'm thinkong about making a page with something like this. Also for software you'd like to see developed. Good / bad idea. Probably best kept to the forum.
Seems people want USB and memory most. Nokia are you listening...
1. A gzip-enabled browser.
2. GPRS
3. Touch-screen
4. A MUCH faster processor.
How USB works, if device what you are connecting to 9210, needs 12v power from 9210? I think it is too much to ask from communicator..
Regards
JeP
a. Faster connectivity -- USB connection
b. Faster Input Method -- Touch Screen.
c. A slim body would be something great.
d. Memory.
Three wants
1. Stereo output would allow the device to replace everything electronic I normally carry. The communicator would then be a very cheap device.
2. More memory - even the 64Mb memory card fills fast with the movie capability.
3. USB
1) more ROM
2) more speed in some appl.
3) GPRS
Seems to be alot of request on the forum for Data program found on the Psion 5.
