disappointed
3 replies · 2,611 views · Started 20 October 2003
Brought my n gage on saturday spent all afternoon sunday trying to communicate the pc. not possible pc suite does not work as pc is not bluetooth enabled what is that about.managed to download audio only held two songs whats the point in that bweginning to wish I had saved my �270 feeling really disappointed at present hope things improve. Even ringtones are crap. Can't afford to buy too many after spending all cash on phone and thats with no credit.
Maybe this'll cheer you up.
have you still got the Floboard game on the memory card? Just copy the system file (on the memory card) onto your computer and it'll allow you to have the full capacity of the memory card for mp3s etc. Pc suite isnt a neccesary program, you can virtually do everything it does using the usb cable.
SAbz
Sabz is right, the only thing where PC suite will be critical is when you will be synchronizing your contact list and calendar with Outlook or another PIM. For transferring wallpapers and ringtones you can use FExplorer as a workaround and it works fabulously.
We have every right to be angry at Nokia for not making the PC Suite compatible with the USB cable. I am infuriated. As for the memory card issue, I think Nokia reneged on including a higher-capacity MMC card in the sales package to keep costs down.
If you are so easily unpleased then by all means stay away from your PC. The 1,000$ price tag on a machine that is inclined to give you all kinds of problems installing drivers is bound to make you go insane.
But I shall reiterate what was said allready. You don't really need the PC Suite for anything, it all can be done with the USB cable.
