mBrainSoftware well know for their Pdf viewers for the Symbian platform have released Fonts for the 9200 series. It enables easy installation, removal and management of fonts on the devices.
Release Information:
The Nokia 9200 Series Communicator has the ability to handle both industry-standard True Type fonts and the Symbian OS specific gdr bitmap fonts.
Using such a font is easy, as they can be selected it in a dialog.
Installing fonts was however far from easy. Until now, font files had to be moved to the appropriate folder manually. The Communicator had to be rebooted, for instance by removing and reinserting the battery. Removing a font was even harder...
With Fonts (for the Nokia 9200 Series Communicator) installing and removing a font is as easy as using one.
Fonts installs itself in the Control panel on the Extras screen. With Fonts running, installing a font file is as easy as choosing it and pressing OK. Fonts copies the font file to it's proper place, installs it ready for use and remove the original file (if one wishes). Removing a font is as easy as installing one. Choose it and let Fonts handle everything else.
Fonts is available at www.mBrainSoftware.com/Nokia/Fonts/Fonts.htm
