how the f~ck do u install jar files on your ngage??????
how do i install jar files when there in rar
If its in .rar format i assume its a cracked game, in which case you wont find the answer on this forum.
SAbz
Games that have the extension *.jar does not have to be a cracked game. The jar format is the java program/game installation file. Compiled in java. To install you need to load it into the N-gage via bluetooth (i assume gprs also works). Then you will find it in "Extra functions/Program" (Not sure if my translation is the same as in N-gage as i use a diffrent language) After a successful install you can run it from the same folder as you installed it from.
The first line should also say "rar" next to "*.jar"
