Deleting email headers manually
2 replies · 2,846 views · Started 16 August 2002
Is there a way of deleting email headers from the messaging application other than reconnecting to the mail account?
I usually check my mails in the morning and download all the headers if I'm away from my desktop, but there can be rather long periods between reconnecting. So I was wondering if there is a possibility to manually delete these headers. There is the remove message option, but it still keeps the headers...
Thanks for the help!
To my knowledge the answer to that is no, as I had the same problems when using the unit to check my e-mail, and as the 9210 just showed you what was in your pop3 inbox, and unless the e-mails were deleted there and re-synced with the 9210 they don't dissappear from mail. Which is most annoying in my opinion. Maybe a more advanced e-mail client could be handy for the 9210.
