Ok, i've been tryng to use this app now and its not connecting to the master server.
I searched the forum and some people say MSN have cut of the gateway so it doesnt work anymore, some people say it works fine.
So what's the situation?
Also, can i use it over Bluetooth and use my pc internet connection rather than GPRS?
I did use it a few months ago but i uninstalled it and i cant remember if i used it over Bluetooth or not...
I'm having the same problem with IM+, can't connect to MSN...can't search through the forum though cos IM+ is less than 4 chars long!
All of the IM programs are having issues with MSN right now die to the MSN upgrade.
Do they still got issues about msn
I cant even open mij IM+ ... says: System Error ... have also resetted my phone.. but it still says the same
I actually got on MSN about a week ago I was very suprised... but then it didn't work... I still cant get on AIM tho! 😞
Try searching with IM+
*Adding that asterisk there does the trick.
yeah,it worked for mi for the 1st 3 times or so but after that i can never connect to the master server. so i deleted it.😎
Just downloaded IM+ v 3.20 from Shape Services and MSN appears to be working once more - however, just looked at their site and its now been updated to v4.0, but have to pay extra to upgrade to that one.
I've just downloaded "IM+ for Java Phones full*, Java version" from Shapeservice...
Now I'm in need of a key... I'm gonna buy it.. i think.. but first.. i need to know if i got the good IM+.. (N3650)
