Do you use voice tags?
5 replies · 2,333 views · Started 23 October 2003
Yes
Why or why not?
Mainly whilst driving (by simply pressing and holding the button on the handsfree headset) to save touching the phone
Do they work well?
Yes, but if being used via a headset, it's best to record them through the same headset. Also, instead of really short words, try longer sentences, eg "Girlfriend mobile" and "Girlfriend work".
just one person uses voice tags?
they work well for everyone?
I started using the neuvoice dial command. I prefer it cuase you can train to mobile , home and work. You can also use it too change profiles and start your camara. Its also seems to work better in my car when it comes to voice dialling.
Mickey
I use voice tags. I find it hard to see the display with out my reading glasses. But, with the push of one button I get my number dialed. Works well for me.
i don't use voice tags, they don't always work for me because tend to end up saying it in a different voice or tone to when i first said it so theres some confusion, i prefer to use speed dial, can't go wrong with those😃
