i am really new to symbian based devices. it`s my first device that series 60 is running on. and i really don`t knw how to run .jar files on my n-gage. can anyone show me step by stem because i tried many times but i can`t do it. I tried some games from < http://my-symbian.com/7650/download/index.php > but my n-gage didn`t see them. i can`t find them to run on my device. i put them directly to my phone. then n-gage didn`t see them. then i put them into "...nokia\installs" folder (because someone told me that i have to do this" and when i go to the applications it says me i have non-installed software. and shows me non of them. when i go to the downloaded section form applicaions it says "System Error!" what should i do? please help me
-> do i have to put the jar file o a specfic folder?
-> if i have to which one?
-> how can i see the noninstalled jar fles from my phone to install?
new to ssymbian and don`t know how to execute jar files. please help...
You can send it via e-mail or BT to your phone.When it(the .jar file) safely lands in your inbox folder just click on it and follow the instructions.
Or,if you have a filemanager installed,you can send the .jar file to any folder via the USB cable,then use the filemanager to navigate to the specified folder click on the .jar file and follow the instructions.
I hope that was clear enough 😊
i have the default application manager installed in n-gage. do i have to install a new file manager? if i have to where can i find a good and free one?
thanks a lot. i made it 😊 and i found a file explorer. your message is very very very very helpful for me... thanks again
