my computer doesn't recognise n-gage
5 replies · 2,312 views · Started 25 October 2003
I don't have no bluetooth and hav a usb but when i connect it there's nothong detected, no removable disk.
is it because i don't have no memory card in ngage?
I run window 98 se and when I plug the n-gage into my computer it does not detect it.but i have tried it on xp and it did detect it as Drive (f).
Only a memory card is detectable using usb, so yea you will need to put one in it.
And windows XP already has most of the drivers needed to recognise the memory card, so try manually installing the drivers from the disc.
SAbz
i came on to say the same thing but when i try to use the pc suite it doesnt work!?
like you know how it says this is the first time blah blah...
i press ok and it just wont accept it i connected it via USB
and i dont have a mem card only sonic.. and i'm running XP
BTW i was just trying to put some images onto the device memory
