i need help.on nokia 3650 - midlets
2 replies · 1,586 views · Started 26 October 2003
okay... let me make it simple.. does anyone knows, how to install MIDlets from MM Card? i use MM card reader devices to write / read data.
what i meant is.. where should i copy / paste the .jad and .jar files on the MM card, and where / how to get it installed directly from the MM card, without connection to WAP? please help.. just some guideline will be fine.. thank you. any solution from the J2ME programmers, plz help..
any method else to install the fExplorer? i meant install/download thru wap? i have no IR or BlueTooth
