I encounter problem about file in N-Gage.
filename c:\system\data\logdbu.dat is sobig amount 2Mbyte.
I can't delete , rename it, when I do it alert "file in use".
Your suggestion are very appreciate.
Clear the call log in the Log application (second view in the app + Options) & change the "Receive report" to "No" in Messaging application Settings (and then back again).
I try delete all receive/dialed call log and receive report is set to "No" already, but it's still same.
I don't want to hard reset machine.
Please suggestion.
Thank you very much.
I can clear log and got my memory back.
