dear all
I have nokia 6600
i have some problem i can't send mms there is error message
so what is the problem ?
there is any diffrent between 3650 and 6600 on mms settings
on 3650 there is IP GATE WAY ADDRESS!!
on 6600 there is no IP but there is PHONE IP ADDRESS
AND ALSO PRIMARY NAME SERVER AND SECOND PRIMARY NAME SERVER
SO WHICH ONE I SHOULD USE ????!!!!
Have you asked your operator (carrier) for the correct MMS access point settings for your phone?
If the operator is good, they can send the settings to you via a configuration message, if you call their help desk, or self-service from their web site.
THANX!
I HAVE BEEN RECIEIVED THE SETTINGS
FROM THEM SO MANY TIMES
AND I CAN'T SEND ANY MMS (ERROR MESSAGE)
SO ?!!?!?!?
PLEASE HELP ME !!!?!?!?
Where have you bought your phone? Are you sure it's not a prototype?
6600 does not have MMS over WAP anymore. It has MMS over HTTP which means that the operator must provide different settings for 6600.
You could try (but I may be wrong still) to figuring out which is the "default gateway" IP address in 7650/3650 MMS settings and adding same address in 6600 "Advanced settings" / "Proxy server address". Add also "80" as "Proxy port number".
I didn't know that...
will it be cheaper or more expensive?
