can i install java games on my ngage without using the pc suite as i dont have blue tooth on my system yet or is there another version i can get ??
installing java games
you can send java games through USB too, or you can send it through internet directly to your phone.
to run from USB:
1. first download a file manager for example FExplorer < http://my-symbian.com/7650/download/sendfile.php4?DownloadID=176 > and install it (it`s a sis file)
2. then connect your n-gage through usb to yur computer
3. create a folder (hatever you wan for example ..\java or it can be anything. or if you don`t want to crete folder put it directly to your phone) and send jar & jad (jad is not necessary) files to that folder.
4. then disconnect your phone...
5. start FExplorer and find the "jar" file and open it. then it asks you that do you wan to install
6. say yes and install it. after installation open the applications from extra menu option... and run 😊
excelent thanks how do install the sis file ?
just connect your phone to the computer via usb. and send the sis file to the phone. then unplug the usb cable. and go to Tools/Manager...
in here the programs that have a black cube in the right of the name is the ones which are downloaded. and with no cube are non-installed ones. find the non-insaalled app you want to install and click to options and select install. then say yes ok bla bla and then it is installed. after installation you can safely delete the sis fiile from your phone.
if you want to remove go to the same place and find the program you want to remove (which must have a black cube on the right) press options and select remove. and again say ok bla bla. and then it is removed.
