Hi,can any one help me,my computer shows no signal of the n gage phone i connected to it but my phone do shows that connect it.Then i went to NOKIA CARE CENTER they say that there is some problems in their software but those whu use WINDOWS XP they can do it.how?? help me. i have already install the driver that is my phone already.somebody help me
My n-gage shows connected to my PC but my Pc didnt even show
Are you connecting via bluetooth or usb?
If its usb and you've got windows XP, just connect the usb cable to the phone and the pc. Wait about a minute or two and the pc should recognise the meory card inside the nagae as a removable drive.
Just drag and drop wat ever file you want onto the removable drive.
Then download a FExplorer from www.gosymbian.com, this allows you to access the memory card from your n-gage.
If its not windows Xp all you have to do is install the drivers that come on the disc.
You cant connect the ngage if you havent got a memory card in.
SAbz
I'v got the same problem. My phone suddenly disappeared from my computer, and I can try to reboot the phone or my computer, still no go. The USB logo appears on the phone.
See my thread about that:
http://www.allaboutsymbian.com/forum/showthread.php?s=&threadid=17230
