Hi peeps
hope someone can help me
ive saved some pics on the n-gage how can i save that as my background image? or even screensaver if poss
Moosa
Hi peeps
Moosa
go to settings --> device --> phone --> standby mode -->
SAbz
HI Thanks SABZ.
Anyone know where I can download Fexplorer from??
Moosa
what's the use of this FExplorer??
See files, find files, copy files, send files, rename files, make folders, launch program installations, set operator logos, keep the backlight turned on, etc.
Everyone should have FXplorer... If you dont have it, go get it...
I downloaded it but it won't install...
I just ran the setup from my pc with the phone connected, but I keep getting a message that the phone is not connected
you hav to send it to the fone first then install it.
Once on the fone go to file manager (or application manager or something like that, its found in the tools section i think) --> then at the bottom of the list shud be the app youve just placed on the mmc --> options --> install
SAbz
I can't find a 'file manager' or something on my phone
the only thing there is is called 'appications' which gives me an empty list.
I can't even find the setup file I transferred to my phone...
Menu> Tools> Manager
Thats the one. I knew it had the word manager in it. 😃
i got everything perfect just gotta install my applications and game on my 128MB MMC
i wanna put this tight matrix background as my background too
Raf, we da shit man
installing fexplorer... move it to the mmc via usb....then dissconect the cable wait 25 secs. and then go into the gage menu tools, then memory and using the joypad click on fexplore.sis and the rest is ok ok yes ok...
