Set automatically pin code for an incoming connection in Bluetooth.
2 replies · 3,082 views · Started 29 October 2003
Hi everibody,
Does anybody know how to accept automaticaly an incoming connection when authentication is enabled?
I'm using a 7650 phone and the user has to introduce a pin code if there is the first time the two devices make a connection (there is no link key stored).
I want to do it by software because the pin is going to be the same for the aplication in each mobile phone.
Thanks in advance.
I have same problem. Do you find how to fix it?
ajsanchez wrote:Hi everibody,
Thanks in advance.
