Hello everyone,
I have been trying to connect to internet via Bluetooth for over 2 weeks.
Everything is ok when I connect to internet via gprs from N-gage. Tecom BT3030 bluetooth dongle is working properly. (I set up a serial port connection) I can use PC Suite for N-Gage, transfer files etc.
The only problem is how to identify N-Gage as a modem. Bluetooth device sees N-Gage for serial port connection, fax but can not discover it as a modem. (can not find it when I search for dial up networking)
I installed N-gage modem options from the cd but nothing happened. I had to add a modem manually after the installation. But this time dial up connection shows up with "modem error".
I appreciate if someone can help. I have a Toshiba Tecra S1 which is new, I have a Nokia N-Gage, I have a bluetooth dongle, all of the gprs settings are ok, but I can not connect to internet.
I think I have made some wrong com port settings, cause when I first paired the devices it showed com4 for the serial port and for the second time it showed com0.
Any suggestions?
