3650 as modem IR or Bluetooth
4 replies · 2,677 views · Started 30 October 2003
The 3650 can only be used as modem by connecting it to my PC using infrared. Bluetooth doesn't seem to be an option.
I do have a bluetooth connection and no IR. Does anyone know of a possibility to use the Windows Faxconsole and my 3650 as modem using bluetooth???
I am a bit afraid this .exe file will set up my modem used for internet and email as well; I only want to use my phone as a fax-modem.. not so sure this will be the solution. But it might be, so tanks for the advice!
I have under Modems on XP - Bluetooth Fax Modem, Bluetooth Modem, Bluetooth Null Modem.
I don�t know if these entries are e result of the Nokia Modem Software or the Widcomm Drivers or PC Suite.
I have seen and tried these options as well. The only problem is that XP doesn't recognise the phone as Bluetooth modem; pairing is needed and the phone can be set up as modem just by Infra red ? A bit confusing..
