Hi all,
Can u put a pic on to your phone from the pc? if so can u put it as a background?
Where do u save the pic file to o the mmc card and where in the menu do u go to to set it for the background?
ALSO
what is the size the pic needs to be shrank to? and what for mat does it need to be?
New to this phone so please dont laugh at me😕.
Briggsy
the images have to be 174 x 132 pixels. If you store them on your MMC, you'll need to move them to your device memory by selecting options / move to folder / Device Memory from the images app in extras. If you don't, as soon as you take out the MMC, you'll lose the picture from the background.
To set it as the background, go to settings / Device / Standby and select background. Choose yes and select the picture you want!
sorted!!! 😃
Thanks for the help m8, but does that apply to the N-Gage. Just in the menu section all I have is the following folders: -
Telephone
Contacts
Calendar
Messaging
Media
Extras
Tools
Profiles
Briggsy
If you go to
menu
tools
settings
device
standby mode
and then background image
you can select and change your background
