memory
12 replies · 2,225 views · Started 31 October 2003
i just pluged my n-gage up to my pc so i could put some different songs on today, but as i took some off, the used memory stayed the same. there is nothing on my memory card but it says that its full! what should i do?
try rebooting first.
that happens to me every now and then.usually when i transfer alot of files. maybe its skipping a process that refreshes the mem size.
but it reads correctly after the restart
sexy beast i tried restarting before but it didnt work. but when i formatted it, the acctuall conection for the computer doesnt work anymore. im soo angry because now i cant do anything and ive only had it a month
You have to empty yhe recycle bin in your n-gage to free up the space. (right click on the Drive letter of your mmc, click on properties,then click disk clean up make sure the box is ticked the press ok). saves you loseing all the data you want to keep
1)Open FExplorer
2)Go to the mmc drive.
3)Go to "recycle" (or "recycle bin, something like that anyways)
4)Highlight everyting in that directory
5)Delete it
If that dont sort it then im unsure, maybe its ur ngage.
SAbz
