Hi there!
SmartAppz-Symbianware is very proud to annouce SmartSecure for Nokia 9210(i) and 9290 Communicator.
Many people have sensitive or confidential data on their personal
computers. Controlling access to this data can be a problem. PDA are highly vulnerable to theft or unauthorized use. Sometimes losing PDA is nothing comparing to the possibility that someone will use your data.
Now you can be sure that no one will have access to your data unless you allow them to!
SmartSecure will help you keep your data from unauthorized use!
SmartSecure features
Security
- Intellectual whole PDA part of device password protection
with many options (Asking password on every cover open,
once an hour, once in three hours,
once in 6 hours, once in 12 hours,
once a day and never)
- All passwords are stored in encrypted view.
- Up to 16 characters in password (numbers and letters) for the
device protection.
- SmartSecure daemon is protected from killing by Ctrl-Chr-Shift-K
or by various TaskMan
- When security violation is appeared your system will be immediately
restarted to prevent access to your data.
- Auto disabling and locking serial port when showing password screen
to disable access to your important data from desktop PC. Optional.
- You can define the hotkey to immediately lock your device with
SmartSecure.
Personalize your device with SmartSecure!
- Fully customizeable password screen
(ability to setup background picture and enter owner
information appearing in any place on password screen and
in any colour)
- Plays sounds that you specify when device cover is opening and closing
Misc
- Auto start feature
SmartSecure for Nokia 9210(i) and 9290 Communicator will be available in about 1 to 2 weeks!
Best regards,
The team of SmartAppz-Symbianware
www..smartappz.de
www.symbianware-com
