Can't figure it out, only sends to inbox of phone memory which gets full.
Cheerz
How To Set Up N-Gage To Save Bluetooth Stuff To Memory Card By Default?
You can store your whole inbox folder on the MMC.
Exactly how do you do that? I've got the same problem. I went to messaging and then options, but there are no options for saving files into memory card in the 'others' section like you do get in other nokia symbian phones.
waitaminute... could the option for saving inbox in mmc be at a diff place?
You can't. On the 3650 you can switch the message store between phone memory and MMC, but on the N-Gage that has been disabled for some reason (probably to garantee you send/receive/view messages even if a game MMC is in the device).
Sorry about misleading you guys,I didn't that the feature has been removed.
i thought so - too bad, you can't send files which are over 4megs or even 2 megs to your inbox like a 3650
