One thing I don't understand about my 7650 is the GPRS connection thing. I set it up to connect to GPRS when available and indeed I get the little G under the reception indicator. When I truly need to connect to WAP sites then I get the same G inside a square.
Using the little application IpView I could determine that when I do a full connect I actually get an IP address. So what does it mean to be always connected to GPRS when available? does it have something to do with WAP Push and/or MMS? and while we're at it, does MMS use WAP Push to transfer messages?
Thanks,
Matan.
