Eye To Avi
7 replies · 2,543 views · Started 01 November 2003
does eyecon works on windows xp?
cause i had windows 98 before and eyecon worked fine on this, than i formatted my pc and changed to windows xp, installed eyecon exactly the same way and i won't work anymore😡
is eyecon not compitable to windows xp or something😕
same here. sometimes it works, sometimes it doesnt...
sometimes it works but with no audio..
Whats the reason for this?
Originally posted by lars
i have it working already i forgot to install the nub codec
WHAT MEAN NUB CODEC ???
it's a codec for the divx that eyecon uses, you have to install this codec to get the converter working. first donwload a divx player from divx.com and than extrat all the files to c:/eyecon, install the ms dos files and install the green pc thing thats a new nub codec if you have done all this i should work😃
