hi i wanted to know what is series 90??
and is the 7700 the first phone to have it???
series 90??huh??
http://www.forum.nokia.com/main/0,6566,010_60,00.html
Yes,the 7700 is the first Series 90 device.
thanx ghostdog but wats the diffrence between it and series 90?
Read the whitepaper on the Forum Nokia link posted earlier. In short: 640x320 pixel screen resolution, touch-screen, newer Symbian OS, new/different applications.
soory meant to say sries 60??
Some forum say 6600 is sysmbian 9. This is right ?
NO. Nokia 6600 belongs to Series 60 Platform and runs Symbian OS 7.0
6600 is based on Symbian OS 7.0s (note the 's'😉 and Series 60 (version 2.0).
There is no "sysmbian 9" 😉 that I know of & most likely the next release after 7.0s will be 8.something.
7700 will be based on Symbian OS 7.0s and Series 90 (version 1.0, presumably).
Three questions
N-Gage, 7650 & 3650 are based on Symbian OS 6.1 and Series 60 (version 1.0). Am i right?
What will the 3660 be based on?
What are the differences between Series60 1.0 and 2.0?
RoYaL21,you are right.The N-Gage,3650,7650 run Symbian 6.1 and Series 60 1.x.From what i've heard the 3660 will run Symbian 6.1 and Series 60 1.x(1.2 most likely).
For differnces between 1.x and 2.0 you can read here: http://www.forum.nokia.com/040?fsrParam=2-3-/main.html&fileID=3779
Thanx GhostDog 😎
its stuppid though, why not release those updates so we can update are phone with newer software (afcourze they wont do that, phone company's want you to buy a new phone instead.... )
Evert,smartphones haven't reached the state where you can install a new OS by yourself.Flash new firmware?Probably,but installing a new OS is another issue.
hi i bought a nokia 3660 and i want to install a theam is it posible to install theams on this type of nokia
No Themes support in the 3660, and it isn't a Series 90 phone either (which is what this subforum and topic is about); the 3660 is based on Series 60 1.2. Search for "Smart Launcher": http://www.allaboutsymbian.com/forum/search.php?
