Does anyone know how to send images from fone to PC without the suite ?
My PC suite wont have any of it at all ! I can send files to my fone easy enuff with my bluetooth but dont know how to send images from the fone without paying for it via email ?!?!?!?
Send Images without PC suite....
You can simply select the image then press Option > Send > Via Bluetooth.
The picture then will be sent via Bluetooth to the PC.
ive tried and tried that til im blue in he face ! just get a sending failed reply. 😞
It's working with me Via Infrared.
well im buggered if im gonna splash out on an IR now ive payid �100 for a bluetooth !
[quote="DaiMonde"]ive tried and tried that til im blue in he face ! just get a sending failed reply. 😞[/quote]
I think you need to do 2 things:
1. set your PC bluetooth settings to "allow this pc to be discovered"
2. "pair" the 2 devices from the 7650 BT app (you go to Bluetooth, press right on joystick and then add a "paired" device. To do so, you may have to set a NUMERIC password on your PC BT settings)
(I believe it's written in nokia manual, since I remember having read that somewhere 😉 )
Let me know if it worked.
its already paired and authorised !! ive sent files ti it no probs, just cant send from it.
uhmm... :cry: I don't know... try setting security on the PC to "low" ...
