basic questions about P800
6 replies · 2,368 views · Started 03 November 2003
i'm new to this forum and the SE p800 and i have some simple question.
please could someone take one minute and write an answer.
*can i watch movies on the P800?
-how is the quality?
-what video-format is needed? *.avi?
*is the biggest memory card that works 128MB?
*is there a MP3-player?
-can i make folders with band-names and do i see the songtitle,ect.?
-can i use normal headphones?
*does it have T9?
*should i give my 7650 away and go for a P800?
All of these things have been discussed at great length in here before (and can be found using the search button at the top of the page). However, as many of these questions are subjective, you will not find many difinitive answers.
Yes you can watch movies, in Mp4. Quality is subjective but not bad IMO.
128MD is the largest standard duo you can buy.
There is an MP3 player, the quaity is very good, you can make folders etc and can use headphones with an adaptor.
It doesn't have T9.
As to whether you should give up your 7650, that's up to you. I would say the 7650 is a great phone with basic PDA functionality. The keypad makes the PDA slow to use.
The P800 has a very good PDA (hampered by poor synch software) but the phone is limited if you are used to the advanced features of many Nokia's.
But the P800 suits me just fine.
As I mentioned, there is masses of content on all the topics you mentioned on this forum. A few searches will provide you with hours of reading material to help you decide.
Perhaps you should wasted your N7560 at once 😉
P800 and 900s are a PDA phone. But if you are not lookin for a PDA feature, then you should perhaps keep your 7650.
Overall of the phone, it's the best so far i have ever use. 😃
i'm going to wait until P900 is available everywhere. than the price of the P800 will drop (at least i hope so)
