Uploading to MM Card for 6600
4 replies · 2,169 views · Started 04 November 2003
Hi all,
I was just wondering if anyone could answer this question please??
If I want to install applications/games to the Nokia 6600, would I be able to use a Memory Card Reader (I've got one that supports MM Cards) & upload the programs to that via the PC , & then put the MM Card back into the Phone & install them from there? or would I have to upload the applications/games via Bluetooth or IR?
Would that work???
Cheers Mark.
yea, thats what i do with my 3650 at the moment. Just make a folder on the mmc that is labeled uploads, or something like that, and when you put it back in your phone just install it from there if there is some sort of file explorer.
yes... it will work. transfer the install [.sis] files on the mmc and run it from there to install
If you install programs from another memory-card, then you cannot install it to memory-card.
That is important, because if you install new programs in to phones memory, you lack it speed.
Thats normal in every Pocket type machine and rule nro 1
Always install all programs to another memory than phones
