60 series games problems
6 replies · 2,676 views · Started 04 November 2003
Hi i've tried many games for the series 60s phones that end in .sis and I can't get them to work. Drugwars loads but just gives me the option to exit, and other games do the same thing. How do i get these games to work on the ngage?
Dunno. I downloaded Prince of Persia and Rayman 3 for my n-gage and both work. The only problem is no audio.
how do you install java games? after pasting it to your mmc, whats next?
Skrue,it has already been answered couple of times before but anway in short you need to have a file manager installed,like FExplorer from www.gosymbian.com,its great and freeware.Then you have to locate the .jar file using the file manager,click it an follow the instructions.
In the future,please search the forum.
Thanks alot ghostdog!!! btw, sorry if it was posted millions of times and i dint do a search.😊 Thanks again
Dopewars... Your only option is to exit? Try using the d-pad to play the game? Anyway yeah, there are heaps of shareware and freeware games out there to try out, look around, most will work on the n-gage that work on series 60 phones.
