dust..
4 replies · 2,726 views · Started 19 August 2002
[quote="john74"]no luck..can anyone corfirm this,where in the hell does it enter from??[/quote]
Mine has no dust yet. But if you turn the backlight on you can see a small hole on the left. If following the line where the silver band and the green shell are in contact, about in the middle of the displa, on the left, you see a small hole.
Hasn't anyone yet come up with a solution to cleaning dust under the screen of the 7650? I have some too and it's very annoying.
Of course I could take the phone to maintenance service again, but I'd sure hope there was a home-made solution. Any ideas?
Tero
youll note it will also get under the joystick and two main buttons, and in between the keypad sliders.
The only option I can think of is, getting one of those tiny tiny keyboard vaccum cleaners, you know the ones they have to get in and clean in tiny places particulary keyboards.
Get one of them and give it a quick clean every night might stop it.
