GPRS settings!
5 replies · 10,299 views · Started 04 November 2003
You can use the Auto config on the SE P900 support site, it will send a text message with all the settings in direct to your phone, otherwise i'd contact T-Mobile and ask for them 😉
I think I can help with this, as I got my mobile from T-mobile:
Account name: T-Mobile GPRS
Connection Type: GPRS
in Advanced/Server:
User: user
Password: (u've got to ask t-mobile people, as it was set up on my phone and don't know what the stars reffer to!)
Address : general.t-mobile.uk
Log in:
Get IP automatically
Get DNS automatically
then choose: no Proxy
hope this would help!😊
Vodafone settings for P900
P900 (GPRS WAP)
1. Click on All on the main menu and then Tools from
the pop-down list.
2. Click on Control panel from the list of applications.
3. At the bottom of the Control panel, click on the
Connections tab.
4. Click on Internet accounts from the list.
5. Click on the New button.
6. In the Account name field enter Vodafone GPRS
WAP
Ensure Connection type is GPRS (if not click on the
arrow in the field to select it).
7. Click on Advanced.
8. Click on the white box of the User name and
password required field.
9. In the User name field enter wap
10. In the Password field enter wap
11. In the Address field enter wap.vodafone.co.uk
12. Click on Done to close the Advanced settings.
13. Click on Done to save this setting.
14. Go to the Control panel (click on the All - Tools - Control Panel).
15. Click on the Connections tab.
16. Click on WAP accounts.
17. Click on New.
18. Enter the Account name WAP Vodafone
19. Set the Internet account - click on the arrow of this field and click on
the name
of the account you created above (Vodafone GPRS WAP).
20. Click on the box of User Proxy to select this option.
21. Enter the Address 212.183.137.012
Leave the other fields unchanged (Port is 9201, Username and password are
blank).
22. Click on Done to enter the settings.
23. Click on the Preferred tab of the WAP accounts page.
24. Click on the white box to set Use WAP account.
25. Select WAP Vodafone as your Preferred account.
P900 (GPRS MMS) )
the pop-down list.
Connections tab.
MMS, ensure Connection type is GPRS (if not click
on the arrow in the field to select it).
8. Click on the white box to set User name and
password required.
9. In the User name field enter wap.
10. In the Password field enter wap.
11. In the Address field enter wap.vodafone.co.uk.
14. From the Control panel applications click on WAP accounts.
15. Click on New.
16. Enter the Account name MMS Vodafone.
17. Select from the Internet account list the account you created above
(Vodafone
GPRS MMS).
18. Click on the box of User Proxy to select this option.
19. Enter the Address 212.183.137.012 (Port is 9201, Username and password
are blank).
Leave the other fields unchanged.
20. Click on Done to enter the settings.
21. Click on the Preferred Tab of the WAP accounts page.
22. Click on the white box to Use WAP account.
23. Select WAP Vodafone as your Preferred account.
24. Click on Done to save settings.
Account Name: T-Mobile GPRS
Internet Account: T-Mobile GPRS
Use Proxy: yes
Address: 216.155.165.050
Port: 9201
Username: (blank)
Password: (blank)
