When online using my 9210 i can access the all about er6 hompage but not the forum,anyone know what the problem is?
viewing forum on 9210
There shouldn't be a problem. I've been able to do it, but I must admit that I found that I was only able to do it after reformatting my machine and re-installing the software.
I have an old firmware and suspect that the newer the firmware, the better your mobile AAER6 experience will be (since later firmware is able to actually run Opera, for instance).
You are launching the forum from the mobile version of this site, aren't you?
I'm guessing you are using the web browser that came with the 9210 as standard, I'd recommend you use opera as I don't think that Nokia's browser is 100% happy with javascript and style sheets as used by this forum.
Yep, use Opera not the STNC browser builtin to 92110. This is exactly the same situ s the 5mx/7/Netbook problem, I need to use Opera to view other forums as well as this one. And ifmyou DO a lot of Web, you should be on Opera anyway. Trust me.
