hi,
i have just purchased MMC and have use my software cd to install the nokia audio manager. but now i am not able to transfer music to it. on my audio manager says that mobile device not found. and i am also not able to get the com free for the usb port. can someone help me fix this problem.
thx
I don�t have an NGage, but I used to have a Nokia 5510, which also supports USB and MP3... (And also came with Audio Manager)
My A.M worked fine, while I was using Windows98 oder WindowsME, but as soon I had Win XP it came up with the same Problem, you have!
Can�t you try to upload music-files via Bluetooth with the Nokia PC-Suite ???
hi,
i dont have a bluetooth card in my pc and also dont know how it works.
i also cant get the com free to use to connect anyway.???
wht u say to this.
thx for the reply though
The N-gage and pcsuite and audio manager only work with Bluetooth. You can use the usb cable and connect to your pc and simply move them into the MMC root and then dissconnect the usb cable (very important, cant use the card in the gage if the usb is connected) and wait a few seconds and then open the music player and select open and open your mp3's from the MMC..
have fun and enjoy
omega
I am current using a 5510 with XP & server 2k3, works no probs.
The nokia audio manager is awkward to use so I use AAM v1.2 (converts music files on the fly instead of filling up the hard-drive with copies).
But as far as I know AAM only works with the 5510.
The N-Gage's Nokia Audio Manager most definitely works with the supplied USB cable. PC Suite is what requires Bluetooth.
