Hi folks
I've come over the wall from the P800 forum as my wife has just got a N-Gage and I wanted to know what are the Top 5 Apps to put on it?
Handy Day? Psiloc Sdoubler? etc what would you recommend?
Also does anyone know if MGS Karting works on the N-Gage? (I have it on my P800 and thought a two player Bluetooth game would be cool!)
The www.nmprod.com & My-symbian sites only mentions the 3650 & 7650. I know in theory it should but I don't want to shell out unless I am sure as having different version for 2 S60 phones makes me dubious!
Cheers folks
Jago
Sorry - That was me! used wrong log on name to sign in!😮
For top 10 applicatons search the 7650/3650 forums.I have apps like Opera,eBook reader,Stacker and you can try games from www.overloaded.com like Fantom Overdrive or Resistance.
You can probably safely try the 3650 version.I think the only difference is that 7650 games can't run from MMC while 3650 games can.
Thanks Ghostdog
I should have realised - I've got all those for my P800! 🙄
Is Stacker much better than Psilocks' Sdoubler?
Cheers
Jago
Stacker or Sdoubler,they are both good,i think its a matter of preference.Both have trial version so,you have nothing to lose.
The Best apps and games on the n-gage
Fexplorer
Extended Profiles
Bemused
Smart Answer
Opera
Guitar Tuner (Works kick ass)
Nokia Game (Flo Boarding)
MGS Cobra Attack
180 Darts
Metal Bluster
Thats the most used software on my phone for the last few weeks
where do you get all those files for the ngage, i only have fexplorer
