How to use nGage as an MP3 player
9 replies · 13,324 views · Started 06 November 2003
It seems that there are a few pitfalls to using the nGage as an MP3 player. Is there anyone out there who has a tried and tested way of doing it?
Things I'd like to know are:
- how to transfer MP3 files to the MMC card in an nGage friendly way
- how to clear the MMC card
- how to support more than one MMC card
- what MMC product works ok with the MMC
- is 128MB the largest card the nGage can handle
- recommended MP3 resolution 64/128 etc
... and anything else you can think of!
Cheers
Sorry to be getting at you but would ppl
please use the search button BEFORE POSTING!
The amount of times these same questions have been asked and answered is stupid.
Dont let this stop you from posting in the future, just make sure the question isnt already on the forum!
SAbz
I put this message in after reading loads of stuff and coming to the conclusion that this message was required. I shall find a working setup (if I buy the nGage) and then put my own answers.
The search engine on this thing isn't too helpful either....
"The search term you specified (mp3) is under the minimum word length (4) and therefore will not be found. Please make this term longer. "
... and putting in "mmmppp333" didn't work either! 😉
PS No worries mate.
here are the answer:
1.through the usb port or bluetooth
2.menu..tool..memory..options..format
3.not possible one at a time
4.nokia origanal
5. original yes but some mmc higher work http://www.tecic.com.tw/news.htm
6.i download them through kazza and put them directly
and cant think of anything else
Ismail is right... been done, been asked... but yes the gage is a cool mp3 player and works great! buy one , I have and really enjoy it!
how do you send MP3's via blutooth
I can send MIDI and WAV files but not MP3'S
1. get a mmc card reader, its cheap, fast , and very easy to use
2. do it from within ngage (select Format MMC from Memory options) or u can try manually deleting files from the mmc card reader or thru a great app called Fexplorer
3. ??
4. -specify-
5. No, i use a 256 mb mmc and it works great
6. Recommended, Encode ur MP3s to OGG format. Use a free software like dbpoweramp music converter and encode oggs at 64kbps, 16000Hz and mono. These sound great and are almost half the size of a mp3 with same quality. Use Oggplay to play these files on your Ngage. However, if u still want to use Mp3 then use 48KBps..
48kbps? 😛
128kbps will do just fine...
MMC cards up to 1GB files look at the forum sticky with tested memory cards!
i have a 256mb mmc....but i cant play mp3's...is there any way i can do it fast & easy
