Hi there,
I knwo you will all say that this in on the forum somewhere and there is a lot of stuff about starting out but if someone wouldnt mind I would a step by step of writing a simple program and every process invovled from installing all the tools for C++ where to install them to and then writing the code saving the files - I presume exporting and building the application testing on an emulator and then creating a Sis file.
I dont need the program to be anything more than just a piece of text being displayed - the programming as far as my experience in programming extends is really easy but its all the other little bits you have to do add to make it work - like for example the extra files containing info and data and stuff....
I know some have tried to help by pointing at "lots of help and tutorials on this site" comments but this doesnt help at all....
I would appreciate everything you can give...
P
