cant put music on my MMC Card
4 replies · 2,167 views · Started 06 November 2003
hi,
i have just purchased MMC and have use my software cd to install the nokia audio manager. but now i am not able to transfer music to it. on my audio manager says that mobile device not found. and i am also not able to get the com free for the usb port. can someone help me fix this problem.
thx
is the mmc recognised as a removeable drive? if not then youve either got to install the drivers manually or another program is using the usb port.
Try looking in the device manager section in control panel and checking.
SAbz
just use the usb cacle and send it to the root area of the mmc... disconnect the usb cable and presto ...look for the music in the mmc and have fun
