6600 auto keypad lock?
12 replies · 17,334 views · Started 07 November 2003
There's a program called Extended Profiles Pro that adds auto-keylock to s60 phones. Works well on a 6600.
Yes it does (well mine does). If you go to Tools, Settings, Security you can enter in the minutes (and the default lock-code). Works great
Will
Isn't that Phone lock and not Keylock?
I think you're right, sorry...phone-lock. Still, it locks the keypad too so that's good enough for me
Will
actually the answer is Yes........and No.
my UK 6600 (bought on Voda ) doesn't have an auto keylock. My business partner's imported Euro model does.
d123 can you kindly tell us the menu navigation for the Euro model to get to this key-pad lock options.
thanks in adv.
Hey people
It is "VERY SIMPLE" to lock the key pad of Nokia 6600 without the help of any software...so don't venture to install any software on your phones that might be harmful or untrusted ...
Well..here it is ..and by the way ..I discovered it by chance when I was in a crowded metro and people were pressing hard to the phone hung on my side..and when I tried to use my phone an hour later I found it,to my great surprise, autolocked for the first time sine I bought it .
well ...now here it is
....[SIZE="6"]PRESS THE [COLOR="Red"]CAMERA BUTTON AND THEN THE STAR * BUTTON AND YOUR PHONE KEYPAD WILL BE AUTOLOCKED/UNLOCKED[/SIZE][/COLOR]
