Hi guys, i have a question were i can buy mmc 512mb for 6600? and how it cost?
N6600 users in the Philippines
are you from cebu or manila
avail at most computer shops at Galeria, shang mall, festival mall, SM City and Megamall
Manila pare, san meron sa festival?
Originally posted by The Party Boyfestival mall, yung mga computer shops tabi ng megacellular show room and TCA. wag ka na umakyat sa floor ng cinema, lang kwenta yung columbia super store dun.
ah ok thanks pare..
i read somewhere that 128mb is d maximum mmc capacity for 6600. anyways, pag gumana ung 512mb mmc mo inform mo nalng ako, tnx.
Hey party boy. still partying ei? Haha. Wussup? How's your cousin?
Does your phone has Opera? My phone doesn't have it either on MMC or CD. Dang.
Msta kobe24, yeah im still partying,always partying. about seanmiguel last week lang magkasma kme,sobrang busy daw sya kya he's not posting anymore and he's planning to switch to 6600.about sa Opera naman wala din badtrip nga eh🙄
about your question read this thread http://www.allaboutsymbian.com/forum/showthread.php?s=&threadid=17580
Guys, what bluetooth dongle would you recommend that works well with the 6600?
Billionton bluethooth. Works so well. Just get the 10m, you don't need the one with 100m.
any Globe users here? i just want to know how to activate the MMS and GPRS i already tired 2951 but there's no n6600 model,pls help😞
gprs
1. go to menu --> tools
2. select settings then access points
3. select options, new access point then use default setting. enter details of the ff:
- connection name : myGlobe gprs
- data bearer : GPRS
- Access point name : ewap.globe.com.ph
- User name <none>
- Prompt password: no
- Password: none
- authentication: normal
- homepage: http://www.globe.com.ph/globe.wmlc
- press option then select advace setting, enter details of the ff:
proxy serv address: 203.177.42.214
proxy port no: 8080
mms
1. select menu options then messaging
2. press option then settings, select multimedia messages then access point in use.
3. press option, new access point then use default settings. enter details of the ff:
- connection name: myGlobe MMS
- access point name: mms.globe.com.ph
- User name <none>
- Password: none
- homepage: http://192.40.100.22:10021/mmsc
press option then select advance settings. entre the ff:
proxy serv address: 192.40.100.20
proxy port no: 8080
Originally posted by The Party Boycorrect yung kay sheri except yung home page ng globe
yung last extension should be .asp and NOT .wmlc
m using wmlc not the asp, that's what globe told me.
whats the diff between wlmc and asp?
thanks sheri😊
Originally posted by sherinmmm.... that's good to know, meaning they fixed it na. kasi dati, ayaw. yung wmlc is a wap page while the .asp is xhtml page
m using wmlc not the asp, that's what globe told me.whats the diff between wlmc and asp?
the gprs is not working i already use asp and wmlc, everytime im connecting it says like this. internet unable to connect what should i do?😞
you can also send this message to 2951
internet n7650
u'll receive 3 messages but only download the myglobe internet,
u can also surf using that.
thanks sheri its working smooth now😊
hey guys, did you try to bring your 6600 to nokia care or semicon or brightpoint to fix the dead pixels one the screen?
Where can we get the opera browser or any other softwares? I only have the Ulead software for PC.
Anyone who has "theme" to share other than "climber"? please send at [email][email protected][/email]. I have eFile Manager on my 6600. How do I change my OpLogo. I dont know what file to replace.
Originally posted by wenifer
hey guys, did you try to bring your 6600 to nokia care or semicon or brightpoint to fix the dead pixels one the screen?Where can we get the opera browser or any other softwares? I only have the Ulead software for PC.
dead pixels needs to be replaced and not fix
check your email
don't change oplogo, once you do, there's no changing it back to the default
check your email
OK, Thanks for the info. BTW, who has a new theme?
