PC Suite Problem!!!
2 replies · 2,162 views · Started 08 November 2003
I've installed my pc suite for nokia 6600, when i open the program, it say that it need a name to identify the phone. i've entered lots of name but it says, you must enter a valid name, what would i do?
Hey I finally managed to solve this.
I will tell what I did: I get better BT diriver for my dongle, which didn't really help. So I decided to deinstall and then install again Nokia PC suite but on different disk, I switch from D to C and this helps and solves the problem. I think if you had installed on a disk which is not the SO disk, you should try this. This worked for me! Christian
I've had the same problem. I called Nokia Careline and they've said that I not have to change the path of installation. I ever should click "NEXT".
And now it works fine.
Greetings
CKL
