log shows 30 mins of time difference!!
5 replies · 2,890 views · Started 09 November 2003
hi
is the any problem with the call register timings??? my 6600 shows a time of 30 mins before in the log than wat it should actually show......
kindly suggest what might the problem be...
thanks
Same problem for me .....
This Problem arised when i Connected it with my PC throught Bluetooth via PC SUITE.
The Problem doesnt seem to go away
I dont know what to do
Well, 2 years ago and search where? Would you mind spare few minutes and tell us what to do boy?
BP
just follow these steps and enjoy...
1. go to clock
2. options
3. settings
4. auto update time should be OFF
5. make GMT offset as +00:00 and update the time and adjust the correct time
6. DAYLIGHT SAving OFF
NOW enjoy..................the problem is over
Wirelessly posted (Mozilla/4.1 (compatible; MSIE 5.0; Symbian OS; Nokia 6600;450) Opera 6.20 [en])
Try turning off the auto time update.
