HOW CAN WE CHANGE THE OPERATOR LOGO WITH NOKIA 6600??? THANKS.
Change Operator Logo?????
Make a .bmp picture with size of 92x25 pixel.Store it in c:\system\Apps\phone\oplogo .The name of the image has to be composed of the MCC and MNC number of your operator,IE: The MCC ID number of my operator is 294 and the MNC number is 1 so the name of my oplogo image would be 294_1_0.bmp.
Or you can try some of the applications that can do this precedure automaticaly like FExplorer from www.gosymbian.com
The question has already been asked,in the future,please do a forum search.
hey, I got a motorola v3 razr, or black, and I'd like to know how I can change it's operator logo, wich is from brazilian operator called Claro. cold you please help me out with that?
You can do it by using System Explorer, go to the picture that you wanted it to be a logo then push the options button file -> set as operator logo and you're done....😎
ok, sorry I'm dumb, but could you guide step by step? I have no idea how to do that
first, should I connect the phone to the pc? if yes, then what?
again, sorry I'm suck when it comes to computers
hey tomxx...
to change operator logo....
for: Mobile, ya must install SelectQ, Fexplorer ver 1.16(above). they just like file manager ok...
open/ E(if ya image was in mmc) image/ mark dos image/ select/ scroll down
and look for operator logo/select/ auto reboot ya phone/wait....ok
if normall pic taken in ya mobile... dos image view look expend.....
if ya want to make dos image proper scale....
PC, use Photoshop or Image ReaderCs2.
image crop to 95x30 pixel (1.21cmX0.38cm)
save it under JPG/JPEG, mode: RGB, Quality : meduim
some mobile can use animation.gif for operator logo....(image dat can be move)
regards.
