Help me please!!, I can't download programs from WAP
7 replies · 3,987 views · Started 20 August 2002
I've been trying to download programs from wap.spruce.jp
When it starts the download, it says Download and install *****, supplied by Spruce Tech?, I press Yes.
Connecting.........(For along time)
Then I get Unable to Install. :x
Is this software compatible with my phone (7650), I think It will be easier if a get a bluetooth connection for my PC, which leads to my next question.
Does anyone know who sells the cheapest Bluetooth adapter with a USB connection?
Thanks in advance for your answers.
I think there may be a problem on the web page since I am able to download the Calculator UP, but nothing else.
All I suggest is that you ensure you have the same default access point for your Services and your Midlet Applications.
Excuse the ignorance, but what is a Midlet? I've heard the term a few times, Do i need another program to run these?
Errggh..This new fangled technology.
Midlets are Java based apps for mobile phones and PDAs, I don't know if the 7650 comes with a Midlet app to run them (you need a prog to run them, kinda like an emulator) I know the 9210 doesn't. But once you have an ability to run them there are Midlet apps for a lot of things that will run on any Midlet enabled device, including many games.
no, you can run it without run a kind of emulator
midlets are installed as standard applications
Midlets rule! They don't work so well on the 9210 at the moment (the runtime environment for them is still in beta but can be downloaded from Nokia), but on a 7650, they're really useful, for example, Reqwireless' Web Viewer application is a Midlet.
i just cant install anything on my 7650. refuses every program... dang.
