AAS mail account troubles
5 replies · 32 views · Started 10 November 2003
Something wrong with my AAS mail account, cant login.
Been that way since last wednesday(or maybe thursday?).
Can someone with powers to check it out.
[email][email protected][/email]
send a new password:
And there used to be a control panel for the mail system, but it aint in the same address anymore?? So i can change the password again.
Thanks!
I seem to get problems with my account on a regular basis, but I really think it is down to my PC, as I never have problems checking or sending from my phone.
When I use MS Outlook all hell breaks loose, I get errors nearly everyday and mail usually goes out 3 days after I sent it. 😞
I'll check this out although I haven't had any problems.
Remember login should be:
username+allaboutsymbian.com
Servers are mail.allaboutsymbian.com for both.
Jyrik - I can reset your account for you is you wish?
Rafe
Yeah, reset away, there isnt anything important there. (except new Your Symbian maybe 😞 )
Thanks! 😊
